2014 Subaru WRX build
8thGenSI
Ok, so here we go again... New car, new system. I didn't finish my last build log, this will get finished because I actually plan on keeping this car. Not going for huge numbers, just a daily beater with some decent sq but who knows what it will evolve to. In the early stages so bare with me.
Here are the plans in a nut shell, haven't finished making all of the gear selections just yet so ideas and suggestions are welcome.
Head unit: Pioneer DEH-80PRS
Front stage speakers: Don't know yet, definitely 3 way active, thinking a CDT set up
Amplification: 2x Alpine PDX-V9, 6 channels will be used for front stage, 2 for rear fill, sub channels are self explanatory
Sub stage: took advantage of getting 2 funkin audio SX 12"s really cheap to use as temporary subs until I decide on a preeminent solution. Going to run them in a sealed enclosure for now.
I have the deck in and the big 3 done so far, more to come soon. Thanks @mylows10 for hanging out yesterday and helping out with the big 3.
Sorry, was a bit dark outside
Wiring harness is all wired up
There is actually quite a bit of room behind the head unit
All mounted up
Final product
I have new gauges and a gauge pod that is going in soon as we'll
Also installed my new Perrin radiator shroud, radiator stays, and alternator cover
Connection at the alternator for the big 3
The 2 ground connections at the negative terminal
Chassis ground
The techflex I used blends well with the factory stuff
I decided the positive lead on the alternator could use some protection, it kind of sticks out in the engine bay like a sore thumb
Using plastidip to provide some barrier
First coat
The plastidip is still drying, will post up a pic tomorrow of the final product.
Not audio related but the stock shift and e-brake boots were made of material that was the same quality of a Walmart plastic bag
Terrible
So I installed a short shifter and alcantara with red stitching shift and e-brake boots, matches the seats and looks so much better.
hit up mike singer, hes the owner of Singer alts. i have one and so far zero problems. mike has awesome customer service and decent prices. MYLOWS10 Sells them
Yea, I need to talk to Jim, He can get almost anything. I don't think I need anything crazy, 200 amps should be more then sufficient to run 2 alpine V9 amps.
Just ordered some speakers.
Got these through Jim (mylows10), will get them soon, always a fast and easy deal when I have ordered through him.
WoofersEtc.com - ES-6IM - CDT Audio 6.5" 100W RMS Slim Cast Inverted Magnet Mid-Bass Woofer
A set of these from krisfnbz here on the forum. He sent me a tracking number with in an hour of sending the payment, looking to be a smooth transaction so far //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
WoofersEtc.com - ES-02 BLACK - CDT Audio 2" Ultra High-End Mid Tweeter Drivers
How many coats did you do with the plasti?
I have done 3 heavy coats so far, going to hit it with 3-4 more coats when I get home. I am going to try and get it thick enough to make it hard to tell that there is a nut and bolt under there.
How much altering are you planning on doing to your panels for your front stage?
8thGenSI
8thGenSI
hollister,CA
Nomejoda
