2009 accord 2.4 mechman alternator need help!!!
DOOM1987
Hey guys I'm new to this site and I recently bought a mechman alternator for my 09 accord since I kept having issues with the stock ones soI'm in search of a smaller tighter fitting serpentine belt and I've had no luck all over the Web . I spoke with mechman but we couldn't fine a solution. I saw someone posted they found a tight enough belt but never posted any part numbers so if you see this please add your educated opinion thank you in advance
Have you tried a Honda forum ??Keep hope alive is on one of them and should know for sure..let me see if I still have the forum info in my inbox to get a hold of him
UPDATE- after months of research and countless deadends i almost gave up until i did some math on the length of the belt and found the exact size I needed 7 ribs and all. It eliminated the squeaky rattling noise I kept hearing when I was at a stop the belt brand is bando part# 7pk1815 and hopefully this helps someone in the future
I have a 2011 Accord 2.4. should be the same correct? About to buy a mechman
Sent from my LG-H910 using Tapatalk
I honestly forgot how long it took I believe the website States how long it takes and yes it was a direct bolt on you just have to change the head of the ground wire witch is also provided with the alternator
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
221
A problem may be caused by your phone's or vehicle infotainment systems' software. Be sure you have the latest software version for your phone and...
so, here is what im working with and end goal and working with 100% factory Car 2009 nissan altima 4 door base radio Music style Country rap...
Well I finally had a chance to hook up the us acoustics amp. What a difference. Still playing around with the 13 band equilizer. The h/u put out...
DOOM1987
DOOM1987
New jersey
JDay
