2007 Tundra Crewmax with JBL / Nav
lildev0426
Hi folks. I really need to get the wiring info for the stereo / spks and including the JBL amp for my truck.
I am installing the following:
(keeping stock hu)
jl cleansweep
fronts - id ctx 6.5's
sub - jl 13tw5
rf t600.4
disconnect rear speaks, sub and jbl amp
i want to run the cleansweep to the t600.4 to the fronts in stereo at 4 ohm and bridged to the sub at 3 ohms. i was hoping to tie the cleansweep into the stock amp speaker inputs to avoid taking the stock hu out at all. i would disconnect the stock jbl amp all together. i was also going to use the amp turn -on lead to the cleansweep and use the cleansweep turnon lead to the t600.4.
does this sound like a legit plan or am i missing something that makes this not possible or feasible?
if i need to use the jl summing device with the Cleansweep -
how would i tap into and sum the signals? do i bring the amp outputs and or inputs into the ssi and then into the csweep? thanks again
lildev0426
lildev0426
Louisiana
lildev0426
