2007 Tahoe Build
Finished product for the 1st try. I did not dig the grilles at all so tore them apart and rebuilt.
---------- Post added at 11:28 AM ---------- Previous post was at 11:27 AM ----------
Decided to change the A Pillars up a bit, here is the final results. Also working on the door panels.
So got one panel ready today to be wrapped. Talk about alot of sanding, took me all day for this one panel.
---------- Post added at 11:31 AM ---------- Previous post was at 11:30 AM ----------
Got me some goodies today! Thanks again Toolmaker!!
---------- Post added at 11:32 AM ---------- Previous post was at 11:31 AM ----------
Final drive door finished, should have the passenger finished up tomorrow.
Got around to getting the Ipad installed in the Tahoe. All that is left is some finishing sanding and have it hydro dipped to match the rest of the wood trim.
Tons of sanding to make this thing next to perfect.
---------- Post added at 11:35 AM ---------- Previous post was at 11:35 AM ----------
Everything is at Liquid Print being hydro dipped. Just waiting on the Arc PS8,
Sundown 125.4's and the Shok Subs. Will start on the box as soon as I get some proper T/S parameters for the subs.
Decided to get fancy with the wiring just for that clean look and should add a bit of protection to the wire, black looms were just kind of meh.
Still waiting for subs to show up and will start the box once they get here.
Here is a few more pictures of some of the final touches before we get started on the box. All parts are back from HydroPrint and turned out very nice!
how do you get to the iPad home button?
You don't it stays on while I am in the vehicle and gets pulled out when I get out. If I feel I ever need a button I can add a push button on a spring pretty easy. The top of the trim panel is held on my neo magnets and the bottom retained the factory clips so It is very easy to take it in and out. Also the Ipad uses this for charging and connection to the 80PRS. Composite A/V Cables for Mobile Video Systems
andrew2944r
andrew2944r
Houston
DocisChief
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
