2006 Civic SI - HELP!
jrotary
I have a 2006 Civic SI and I'm a total car audio newbie - here is a list of items I have going in very soon:
-Kenwood DDX7015 Headunit
-Pioneer TS-A1372R 5-1/4" 3-Way Speakers
-Pioneer TS-G1642R 6-1/2" 2-way Speakers
-OEM Amp Bypass
I ordered these items from Crutchfield (so fitment is confirmed) along with a Schoche dash kit for the installation - a local stereo shop will be handling what I will assume is a simple job.
Which speakers should I put in the door and which should I put in the rear deck? Does it even matter?
These are simply starter speakers. I will be bypassing the OEM amplifier so I will lost my OEM sub and tweeters. I figured I'd order some simple speakers so that I'm not running solely on OEM 1 way speakers.
In the future, I will add a 4 channel amp, nice components and a sub (and run the rears off the HU). That is why I got such inexpensive speakers - later on, I will use one set in the rear and ditch the other when i choose components.
Should I have dynamat installed on the doors? Will it even make a difference with just a HU and speakers?
Speaker specs are below:
TS-G1624R
6 1/2
2-way
Dome
Tweeter Composition Polyetherimide PET film
Woofer Composition IMPP composite Carbon Graphite IMPP
Woofer Surround Cloth
Sensitivity 90 dB
Frequency Response 40 - 30k Hz
RMS Power Range 2-30
TS-A1372R
5 1/4
3-way
Tweeter Design Dome
Tweeter Composition PET film
Woofer Composition Carbon Graphite IMPP
Woofer Surround Butyl Rubber
Sensitivity 89 dB
Frequency Response 35 - 31k Hz
RMS Power Range 2-30 2-35
Thank you all!
Jonathan
It is 6.5" in the doors and in the rear deck. The rear deck has pretty much no clearance due to the trunk tension bars.
Check 8thcivic.com for my vehicle specific information.
jrotary
jrotary
Long Island
lostdaytomorrow
