2002 Sunfire Installation & PassLock II
  • 5
CarAudioAddict
What did I do now?
439
Alberta
I've searched google, msn, about 5 different forums, and also asked my local GM dealership and cannot find a definitive answer to these questions
My sunfire has just a stock AM/FM radio - I didn't care because I knew I'd be upgrading the sound system eventually.
1. Do all 2002 Sunfire's use the PassLock II system? Mine's an SL model with no extra features (not even tilt steering)
2. Is there a cheap way of bypassing the System? I'm not paying $100 USD for a wiring harness unless I have absolutley no other cheaper choice.
As I understand it, if the PassLock II doesn't recieve an "I'm OK" signal from every component attached, the car won't even start. so for my third question
3. Why on earth would any company do this to their system? This is just another (only?) excuse for someone to steal a stock stereo - to screw with the owner of the vehicle.
I believe you are talking about the class II data bus system. Quite honestly, there isn't a way to properly do it cheaply. There are many harnesses that can be had for about 70. Its worth the money.
Maybe it's the class II data bus....
The GM techs at the local dealership called it a PassLock II, probably the same thing.
Any idea where I could get a harness for that cheap. Everywhere I've looked so far it's $100+
You've been misinformed. The Passlock system has nothing to do with the radio; it's just a resistance built into the ignition switch and is intended to prevent hotwiring the ignition.
The Class II data bus system is what you're thinking of, but removing the radio won't hurt your vehicle any more than unplugging a USB device will hurt your computer. You'll lose any functions that are controlled by the radio unit; in your vehicle, that pretty much comes down to warning chimes. If you remove the factory radio you'll lose your door chimes and the warning chimes that tell you your lights are on.
If you can live without the warning chimes, then go ahead and use a Metra 70-2003 harness. The only other issue with the installation is that you'll need to find another source for accessory power, since none exists behind the head unit.
Some GMs with the Class II data-bus have had issues with air bags and service engine lights. I am just very cautious when it comes to them. Thats why I always use integration harnesses. I have heard of people not using them and being just fine, I just dont do it.
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
I have a 2001 Nissan Sentra GXE and I've never found one. The loc is the next best option
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
CarAudioAddict
What did I do now?
CarAudioAddict
Alberta
crhye250r
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
