2002 civic on a tiny budget.
mattbhm
Hello! I made a post yesterday over on CarAudioForum(Not sure if the forums like each-other but lets hope so.) and got tons of help, but you can never have enough opinions.
My sister just bought a 2002 civic. The stock radio was shot, along with the front speakers. Back speakers are missing.
We got her a Kenwood BT518HD head unit, and she said she wants to get some better speakers.
Taking into consideration her budget is under $100, cheaper is better, an amp is not an option unless someone has one real cheap used. So that limits the options on speakers, a lot.
I do have an old Kenwood 50W RMS x2 channels @4 ohms that I could possibly use but honestly I doubt I will. We can get something better when she has a bit more money to spend.
We're looking at, https://www.amazon.com/gp/product/B000P0PF9G/ref=as_at/?imprToken=Aso8kdjBqsNz9aj6vFr.DA&slotNum=11&ie=UTF8&camp=1789&creative=390957&creativeASIN=B000P0PF9G&linkCode=w61&tag=stereo0c-20&linkId=STCND6UMCXOZU2BP
OR
https://www.amazon.com/gp/product/B00ANIECRQ/ref=as_at/?imprToken=Aso8kdjBqsNz9aj6vFr.DA&slotNum=14&ie=UTF8&camp=1789&creative=390957&creativeASIN=B00ANIECRQ&linkCode=w61&tag=stereo0c-20&linkId=MLTRDVENKVVHG4QO
AND
https://www.amazon.com/Pioneer-TS-G1620F-2-Way-Coaxial-Speaker/dp/B07595G6H7/ref=pd_lpo_sbs_107_t_0?_encoding=UTF8&psc=1&refRID=C33JJP26GF120910HJPV
I'm thinking Pioneers in the back and either the JBLs or Polks up front.
Thanks!
i like my kenwood hu, make sure hu has a xover on it (read specs on them) u can set the xp filter for front an rear speakers to say 70hz or 60hz,50hz change it around so they don't distort (worth more $ i promise).. polk speakers normally sound good don't usually get that loud.. these be good up front (check mount depth of car before ordering anything) https://www.amazon.com/JBL-GT7-6C-Component-Speaker-System-Set/dp/B00OYGV6IQ/ref=pd_sbs_107_6?_encoding=UTF8&pd_rd_i=B00OYGV6IQ&pd_rd_r=DX74A2CZ7NFZ3G2AE8EA&pd_rd_w=M8ixM&pd_rd_wg=WQebN&psc=1&refRID=DX74A2CZ7NFZ3G2AE8EA
Thanks for the info!
I don't believe the fronts in this car have those little tweeters in the column like some so could I still use a component? Or should I just get the GTOs in the OP?
Also, the speakers don't have to get all that super loud. Looking for nice clean music at medium sound levels.
polks are fine.. u can add the tweet, they should come with diff mount options may even just stick on but those may not have that.. like hertz said look at speaker on parts express some of the cheap speakers will amaze u but if u don't have amp and dsp or xover for tweet u may could just use the mids for rear (we don't use rear speakers) so just a mid in back (if hu has 70hz xover on it) will be good and like he said u could find a pair for $20 and get a comp set for front (is more time consuming to install) or spend few $ u save on rear speakers on hu.. i'll check your hu model # see if it has xover
Never seen them. If they're that good, I may just get them and save the rest for a small amp/sub!
Should they run well from my HU power?
They will be fine on head unit power but get a small amp or even that old Kenwood u have would be fine
I'm not 100% sure what 2 channel means, I assumed that means 2 speakers? So I could only amp the front or the back?
yeap that hu has hp xover on it so u be good.. also lanzar makes pretty good sounding coax for cheap https://www.parts-express.com/lanzar-mx62-6-1-2-180-watt-2-way-coaxial-speaker-pair--267-7164
Thanks for looking! I couldn't find much on it! I'll look into the xover!
Two channels means it has two channels lol. Ch1 and ch2. Focus on front stage. Ch1 left and ch2 right. Or ch1 6.5s and ch2 tweets
I know I probably sound stupid. I take that back, I KNOW I sound stupid.
I've never touched car audio and the only sound systems I've done have been pull them out of the box, place speakers around the room and hook it all up.
I attached a picture of my amp. I guess my question is, can I run all 4 speakers off of it?
https://imgur.com/a/TY5oS
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
I have a 2001 Nissan Sentra GXE and I've never found one. The loc is the next best option
994
Polk Audio DB Series with or without an amplifier. MM Series on an amplifier
563
Looks good so far. If you ever need more up front, Q-forms makes some kicks to fit that civic, we use them in my brother's with good results...
947
mattbhm
mattbhm
Birmingham, AL
shredder2
    May 18, 2024
    May 16, 2024
