20.1 strapping questions
04_edge
iPhail.
ok, so im having a hard time selling my 20.1, but i realized that they will do 3600 watts strapped at 2 ohm...how does that work though? like right now my is wired in parallel and the amp would be seeing 2.2...so with a strapped pair would that be the final load? or how does that work?
If you have (2) 20.1's strapped on a 2.2 ohm load, then they will have the combined output as if each amp was on a 1.1 ohm load.
When you strap the amps, the load each amp sees is 1/2 the actual load.
Brian
edit: WOW - guess I am a slow. . . //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
04_edge
iPhail.
04_edge
Rowlett, TX
Brian Owens
michigan born
    May 14, 2026
michigan born
    May 14, 2026
