2 xplod 12" Need help!!!
well.. the box you build or buy will be worth more than the subs.. if you want cheap subs that sound decent try infinity reference 1250w subs.. they only need 200-250 to sound good and do great in sealed boxes..
Default Sony XM-504X 4ch amp
permalink
XM-504X 4/3/2 channel
- 50Wx4 into 4 ohms, 20-20kHz, at 0.04% THD
- 50Wx2 + 130Wx1 into 4 ohms, 20-20kHz, at 0.1% THD
- 70Wx4 into 2 ohms, 20-20kHz, at 0.1% THD
- Adjustable 50 - 200Hz 12dB/Oct HPF/LPF w/defeat
- 40Hz Lo frequency EQ adjustable 0 to +12dB
- Individually adjustable input gain controls
- Independent Left + Right LED level indicators
- High level inputs
- Discrete FET predrivers, Bi-Polar final stage Regulated MOSFET power supply
- Dual mode operation allows stereo & mono drive
- Protection for temp, voltage & current faults
- Balanced input circuit for noise isolation
- Chassis mounted gold plated RCA/screw terminals
- dim:13 1/8 x 2 1/8 x 11
haha im broke cant afford anything else...... but im prolly gunna get more for this but i thought they sounded alright
don't listen to the fegs here who flame you, equipment isn't cheap, and it takes a while to put a whole system together. You gotta take it step by step.
so will this amp run the two 4 ohm subs on mono?
permalink
- High level inputs
489
375
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
412
johnny0813
johnny0813
Fluvanna
scoob8000
maylar
    Jun 2, 2024
    Jun 1, 2024
