one more question
johnny0813
so will this amp run the two 4 ohm subs on mono?
Default Sony XM-504X 4ch amp
permalink
XM-504X 4/3/2 channel
- 50Wx4 into 4 ohms, 20-20kHz, at 0.04% THD
- 50Wx2 + 130Wx1 into 4 ohms, 20-20kHz, at 0.1% THD
- 70Wx4 into 2 ohms, 20-20kHz, at 0.1% THD
- Adjustable 50 - 200Hz 12dB/Oct HPF/LPF w/defeat
- 40Hz Lo frequency EQ adjustable 0 to +12dB
- Individually adjustable input gain controls
- Independent Left + Right LED level indicators
- High level inputs
- Discrete FET predrivers, Bi-Polar final stage Regulated MOSFET power supply
- Dual mode operation allows stereo & mono drive
- Protection for temp, voltage & current faults
- Balanced input circuit for noise isolation
- Chassis mounted gold plated RCA/screw terminals
- dim:13 1/8 x 2 1/8 x 11
It says two channel so try it if it doesn't sound right unhook it and ask someone at a shop or something for a little more hands on help most are willing if your respectful to them. It should do it at about 130w a piece.
No, it says it will do 130W x 1 @ 4ohm. If you have two 4ohm subs in parallel, that would be a 2ohm load, which this amp cannot do. If you wire them in series, that would be an 8ohm load, which would not make the rated power.
johnny0813
johnny0813
Fluvanna
loopkiller
Mike Mccabe
