2 xplod 12" Need help!!!
so will this amp run the two 4 ohm subs on mono?
Default Sony XM-504X 4ch amp
permalink
XM-504X 4/3/2 channel
- 50Wx4 into 4 ohms, 20-20kHz, at 0.04% THD
- 50Wx2 + 130Wx1 into 4 ohms, 20-20kHz, at 0.1% THD
- 70Wx4 into 2 ohms, 20-20kHz, at 0.1% THD
- Adjustable 50 - 200Hz 12dB/Oct HPF/LPF w/defeat
- 40Hz Lo frequency EQ adjustable 0 to +12dB
- Individually adjustable input gain controls
- Independent Left + Right LED level indicators
- High level inputs
- Discrete FET predrivers, Bi-Polar final stage Regulated MOSFET power supply
- Dual mode operation allows stereo & mono drive
- Protection for temp, voltage & current faults
- Balanced input circuit for noise isolation
- Chassis mounted gold plated RCA/screw terminals
- dim:13 1/8 x 2 1/8 x 11
;p;
props to rev for the only useful reply so far!
OP, that amp isn't really enough to push one of your subs to it's fullest potential.
Hang on to the subs for now and look for a bigger amp, take things one step at a time if money is tight. When you get an amp, go a little bigger so you have some room to grow.
FWIW, I used to have 2 xplod 12's (350w rms each) and two xplod amps (380w rms each), one amp for each sub. Despite what people say on here, it got **** loud considering how little cash I had in the whole setup.
johnny0813
johnny0813
Fluvanna
scoob8000
Mike Mccabe
