2 strapped amps on one dual 2? HELP!!!
  • 4
Okay so I have an PSI/American bass 15 dual 2. Currently it’s wired at 1 ohm.
The guy I got it from had it on two sundown 1500s but I failed to ask him how he had it wired and if his amps were running it stable at .5 or 1 or 2 ohms since they were the old 1500s I assumed it wasn’t .5
I was going to two it’s on two ap2k minis (oscoped) I’ve seen test of these running at .5 ohms just not recommended for daily. Is it possible to stay at 1 ohm on a single dual 2 on strapped amps?
Or would it be 1, 2, 4 ohms? Someone else said this is 1ohm on a single sub 2 amps but doesn’t say what the voice coil is. Please let me know ASAP
Pic for reffered diagram
Options are 1ohm; each amp at 0.5Or 4ohm; each amp at 2ohm
So at 0.5 I risk messing up the amps and voiding warranty since they both are 1 ohm stable. Or since they are working together 0.5 is okay?
If I run the sub at 4 ohms and both amps now =2 ohms it would be about the same power as running one amp at 1ohm?
There was a video on here about strapping amps and what actually happens if you use a scope or meter to gain match. Really informative it was. See if I can find it.
Really just need to know if the amps will be okay at 0.5 but I heard if the slave gains are =/- than master amp you shouldn’t have any problems clip/distortion wise.
I've run plenty of older Sundown 1500s at 0.5 ohm. Actually can't think of a Sundown mono that I haven't run at 0.5.
I wouldn't say that makes it better. It might make it better for you. Not sure I would be worried about spending money on DSP if I was going to...
349
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
910
Tookoff
Tookoff
Louisville,KY
Tookoff
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
