2 strapped amps on one dual 2? HELP!!!
Okay so I have an PSI/American bass 15 dual 2. Currently it’s wired at 1 ohm.
The guy I got it from had it on two sundown 1500s but I failed to ask him how he had it wired and if his amps were running it stable at .5 or 1 or 2 ohms since they were the old 1500s I assumed it wasn’t .5
I was going to two it’s on two ap2k minis (oscoped) I’ve seen test of these running at .5 ohms just not recommended for daily. Is it possible to stay at 1 ohm on a single dual 2 on strapped amps?
Or would it be 1, 2, 4 ohms? Someone else said this is 1ohm on a single sub 2 amps but doesn’t say what the voice coil is. Please let me know ASAP
Pic for reffered diagram
Options are 1ohm; each amp at 0.5Or 4ohm; each amp at 2ohm
So at 0.5 I risk messing up the amps and voiding warranty since they both are 1 ohm stable. Or since they are working together 0.5 is okay?
If I run the sub at 4 ohms and both amps now =2 ohms it would be about the same power as running one amp at 1ohm?
There was a video on here about strapping amps and what actually happens if you use a scope or meter to gain match. Really informative it was. See if I can find it.
Really just need to know if the amps will be okay at 0.5 but I heard if the slave gains are =/- than master amp you shouldn’t have any problems clip/distortion wise.
I've run plenty of older Sundown 1500s at 0.5 ohm. Actually can't think of a Sundown mono that I haven't run at 0.5.
Tookoff
Tookoff
Louisville,KY
Tookoff
