2 RE Audio 12" XXX (Industry's #1 SQL Subwoofer)
centergod79
TEAM BEETEM
2 RE XXX Subs 12" Only Used for 1 1/2 Months
For all you SQL nutz out there, here are 2 of the car Audio Industry's best SQL Subwoofers.
with 54mm of xmax, 2000 watts of rated power, you will need at least 2500 watts on each sub though, and your power must be true clean power, any type of clipping will burn these subs up quick. I personally think these subs ****, but hey, I'm an SPL nut, but I'm a fan of the old RE XXX because they were more versitile, and did a much better job at higher frequencies, as well as the low, lows. But, I can insure you this, if pure SQL is what you're looking for, then these are the woofers for you.
750 shipped (the price is for both woofers)
I will ship immediately following payment, no slacking, the same day if early enough. These are the same 2 I had posted before, but the buyer never showed up for the local pick up. However, I will take 700 picked up
A Link would be very helpful. Id be interested in taking a look at some gear
257
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
373
centergod79
TEAM BEETEM
centergod79
Martins Ferry, OH
CharlayBoy11
