2 questions about electical.
i meant running multiple runs.
1 run of 0/1 gauge wire
and running 4 gauge together
front batt==========================0gauge rear batt
front batt -----------------------------------------------4 gauge rear batt both> to mmats 3500 amps
1 run of neg and pos for 0 gauge and for 4 gauge total 4 wires from batt to batt.
All I know is I have 100 foot of 0 gauge sitting in the corner of my bedroom just itching to be put in my vehicle... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
agm batteries have a lower IR than any regular wet cell battery i know of. CA and CCA will not directly feed into what has more power....too much of those tests are in a voltage range that is unusable for a modern car much less an audio system..
If your running 7kw, you shouldn't be messing with 4 gauge at all. It's not worth it. You will need to fuse the 4 gauges at their ratings (150 amp) each. That's an *** load of fuses. Sell the 4 gauge and get yourself more 0 guage or even 2/0 gauge welding wire. Super heavy stuff. Rarely seen and a pain in the *** to bend or crip onto terminals. Multiple runs of 0 gauge are easier to find and work with.
Don't do lead acid inside. The gases can eat thru steel, and are poisonous. They will ruin your amp, your car and your lungs. When I say ruin, I mean burn a 2 inch whole straight thru.
i did research about agm and gel, and there is nothing special exept price.
they have low resistence means they will change faster, but you still have to wait till they charge, maybe not as long as acid batt. and you can blow agm if not careful.
nsb90 is an acid filled wet battery so whats the hype?
i did research about agm and gel, and there is nothing special exept price.they have low resistence means they will change faster, but you still have to wait till they charge, maybe not as long as acid batt. and you can blow agm if not careful.
low resistance also means quicker discharge to your amp to use the reserve capacity of the battery without the voltage dropping as sharply. When 'buying' a battery for car audio, you should never consider lead acid. It's cheap for a reason.
AGM the acid/liquid/water is suspended in a glassmat. AGMs as a general rule charge faster and discharge better than a add water too type cell. In and AGM cell you wouldn't get your hands wet unless you touched the mat inside..it is also very toxic. I do believe the NSB is an AGM cell as optima, odyssey, kinetik all are. AGMs don't vent nor corrode like add water too batteries and even other "maintenance free batteries.
Gel cells are known for high Ah capacity but generally speaking have a lower discharge rate than AGM...they use gel cells in applications like in solar cells where they use many batteries to draw from and are generally not in high current needed systems. thus they take full advantage of their capacity over drawn out periods of time.
I like FI
I like FI
miami
audiolife
