sound mat question
quins90lac
ok i got a question the under lay meant under my trunk carpeting is all messed up .it got ***** fluid spilled on it long story well any way the other day i tried to clean it and parts of it just like fell apart .so im wondering what should i put in its place a damper , barrier , or a absorber mat im planing on covering the whole in side of my trunk while im at it so what should i use
Depends on how well you want to do it
SInce you are going to be redoing everything why not do it up?
First lay down a vibration damper, like Damplifier Pro, then lay down a barrier like Luxury Liner Pro.
This is an amazing combination.
ANT
ok i see that your a second skin rep so ill probity get stuff for this but is there any one brand that's better than any other . i read the tech sheet for second skin and ive read the one for scosche accumat and they both are about the same . ive used scosche EFX wires and never had any problems with them . so is there any real difference between the two
that's why i said ill probity get sum stuff about the question .i just didn't want to buy some thing when some thing else is same but at a lower price and feel cheated out of money but if second skin is better then ill probity go with it
no disrespect but expect a biased review from ANT ... ( second skin is the shit though no doubt)
My review might be biased but the specs of the product are not.
Accumat
1.5 mm thick
.45 lbs psf
4 mil foil
400 degree heat rating
Damplifier Pro
1.75 mm thick
.65 lbs pst
6 mil foil
500 degree heat rating..
ANT
I know there was raamat b stock selling cheap perfect for a floor and if you put liquid deadener down i know where you could pick up 2 gallons cheap. Then ensolite or that luxury liner over it and it would be nice. make that car real quiet.
quins90lac
quins90lac
peoria IL
gotparts90
