2 guage for battery relocation
Completely forgot he even asked that, but he's talking about battery relocation from what it seems. Does that mean you're going to move the primary to the trunk, and supply power to the starter etc with it? o.o
yes that is what he would like to do...he's done a engine swap and is tight on space
I would not move the main bat to the trunk to much bad shit can happen and almost no benefits
what can go wrong?
Shoot me an AIM message if you can. My SN is Teslawashere.
Well, the only thing that could go wrong is if you do not have a large enough wire, and remember, current will ALWAYS be flowing in that wire, so I would recommend 2 or 3 runs of wire from the battery in back to where the normal battery wires are and do it that way personally. There is no problem, except if you use a normal lead acid car battery, it releases hydrogen gas while charging and under a load, so vent it or get a sealed battery of the sort.
does this look right?
thormxkid
thormxkid
ontario
thormxkid
