2 farad capacitor wont charge HELP!!!!!
rada194
Okay guys this is my first post so if I am putting it in the wrong section I'm sorry.
Alright onto the question. I have 4 gauge power wire running directly from the battery (with an inline fuse of course) that goes all the way to my trunk were it goes into the capacitor then goes into the amp. Then I have the amp grounded. And then the capacitor grounded seperatley from the amp. When I go to charge the capacitor I place the 1k resistor on the power wire and on the capacitors positive terminal. I also have a voltmeter monitoring the voltage as I charge it and it will get to .5 of a volt and stop charging. So what is the problem? Is my ground not sufficient? Is my capacitor bad?
Thanks in advance guys. I hope to see brilliant answers lol...
No resistor. Caps charge themselves. They are not like batts. Jeez.
Every cap I ever ran, before knowing more about caps and batteries, I had to charge first with a resistor. You have to touch to resistor directly to your battery and cap positive then install. But as everyone has said, toss it for another battery. Get a half size kinetic off ebay, they are less then $70 shipped.
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Going all Knu for wiring, lugs, and fuse holders. Been using them for the last serveral vehicles and love their products. Battery terminals...
rada194
rada194
Miami, Florida
ace_800
    May 12, 2024
Brendon Jenness
    May 11, 2024
