2 Alpine Type R 1243D Dual 4ohm with crunch 1400.2?
ERIKCABRERA
Hey guys i got a quick question, i have the new model alpine type r 1243d, I want to use a crunch 1400.2 amp at 4ohms 1 channel that gives 1400rms, now if i put inner positive to inner negative with the jumper cable on each sub, and connect the speaker wires to the outside positive/negative, i should get the amp to give me 4ohm, and i put it on mono instead of stereo. Now m question is since my subs are 600rms max, this setup should give it 700rms to each one but i hear that crunch is over rated so would this amp be fine for these subs?
Heres the amp info:
2 Channel - 4ohm
1400 Watts x 1 ch @ 4 Ohms
700 watts x 2 ch @ 2 Ohms
350 watts x 2 ch @ 4 ohms
Bridgeable amplifier
MOSFET outputs
PWM digital power supply
High level inputs for OEM Radios
Fully Adjustable Crossovers
SEPP A/B Class Amplifier Designs
All 2-Channel and 4-Channel Feature Bridgeable Designs
CRUNCH Illuminated Logo
Rugged MOSFET Pulse Width Modulation Power Supply for Instant Maxx Power Output
1-Ohm Capable A/B Class Mono Block Amps
2-Ohm Capable A/B Class 2/4/5-Channel Amps
So this is how i think about connecting everything.
hmm? How could it not, i understand its not a high class amp but ti should at least work fine with the subs, or your saying that if i do set it up the way i want to, this amp will not do anything at all to it?
It is rated the same way but theres no way to connect these subs like that, i checked the manual and 2 4ohm subs cant be connect so that 1 amp gives it 2ohm
ok so if this amp is no good, would you say that i should get the JBL GTO-14001 thats 1200rms at 4ohms x 1channel?
Wire each sub in parallel and run them to each channel. That would give you the 700x2@2ohm like the amps supposed to do. I read earlier someone say an audioque 1000.1 was around 100ish if I remember correctly. If you already have the amp then I'd say use it. If not look for a 1ohm stable amp that will power them. Hope that helps
i tried that once and the bass was soft, i know it because the amp is a low class amp. Ok so what amp do you recommend for my subs, i was thinking on the JBL GTO14001 but its a A/B Class so its might not be good, i need a amp thats 1000-1200rms at 4ohms x 1 channel
ERIKCABRERA
ERIKCABRERA
B-wood, New York
Vossy
