2 8"s or 1 12" SQ setup
  • 5
Iosias
Im looking for suggestions on what pair of 8"s or a single 12" would be a solid SQ performer in the 250$ range. Whatever the rms requirements ill buy an amp accordingly.
If I go two 8"s I can port them or a single 12 sealed.
Any suggestions would be great.
the concern with multiple subs is coherent coupling of the wavefronts.
a single sub simplifies everything.
the concern with vented enclosures is coherent coupling of the woofer output and the port output.
a sealed enclosure simplifies everything.
a pair of 8's vented is several orders of magnitude more complicated to sound as good as a single sealed 12.
both can do the job. one is much easier to implement successfully.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
605
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
930
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
Iosias
Iosias
United States
wenn_du_weinst
audiobaun
    May 19, 2024
    May 19, 2024
