2.67 ohm load
How many watts would an amp rated at 1200 watts @ 2 ohms put out @ 2.67 ohms? 3 10 inch woofers dual 4 ohm would be bridged down to a 2.67 load.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Are you fucking kidding me?
I demonstrated two different methods to use to approximate this on your own in your other thread.
http://www.caraudio.com/forum/showpost.php?p=5077685&postcount=11
And yet you still started this thread?
I know this is waaaay late, but I see this question a lot. I won't bore you with the math, but I used nonlinear regression and the specs at 1,2, and 4 ohms to estimate the watts RMS @ 2.67 ohms. You theoretically should get about 991 watts RMS; the R-squared value is not ideal, but it's close enough to 1.0 be confident in the formula Excel spit out.  Hope this helps someone...
That question probably gets asked a lot due to the poor math skills nowadays.  Or they want to be able to say how much they are sending from the amp at that load to impress their friends...?
The measured DCR (direct current resistance) of a stationary voice coil is not the same as the nominal impedance presented to the amp under normal use. When the coil heats up it will increase the resistance also music isn’t static so the load will vary with the signal. Dyno testing at a specific resistance may yield a specific number...but that will only give you an idea of the amps capabilities.
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
174
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
833
cleansoundzz
cleansoundzz
Buena Park
shredder2
    Apr 28, 2024
    Apr 28, 2024
