2 12's on mb quart onyx 1500
they guy im tryin to beeat has 2 15's and he hits a 147 hes my goal to beat //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i was actually lookin at those i hear they get pretty low cheap as hell too, how would they compare to the obsidians?
obsidians are better IMO but the DX's are still impressive
They take a lot of power and don't get stinky!!! And they play super low I saw 6 12's in an explorer on an NS1 and it was serious flexxing
awesome //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i love the lows how would 2 12's compare to 2 vvx 10's on the same amp? kinda louder or significantly louder? sorry for the 20 questions but moneys tight these days so i wanna make sure ill love em //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
IMO it all depends on ur box. i like the obsidians over the vvx's and u will get slightly more cone area but those subs performance wise i think are pretty close. make sure ur box is right and ur set
Skar VVX10:
Re : 3.8 ohms
Fms : 26.6 Hz
Res : 60.4 ohms
Qms : 4.32
Qes : 0.46
Qts : 0.42
Rms : 8.6 kg/s
Cms : 0.16 mm/N
Mms : 222.6 gr
Nref : 0.10%
Bl : 17.5 n/a
SPL : 81.8 dB
Vas : 24.5 L
Rp : 34.5 ohms
Lp : 53.5 mH
Cp : 909.5 uF
Le : 3.09 mH
Rms : 600 Watts
2.5" Voice Coil
Obsidian 12:
Re: 4.0 Ohm
Fs: 33 Hz
Qms: 5.21
Qes: 0.56
Qts: 0.51
Vas: 34.4
Le: 4.36 mH
BL: 19.1
SPL: 85.4 dB
Sd: 490 cm^2
Mms: 243.1 g
Xmax: 20mm
Peak-to-peak: 62mm (2.45")
Power Handling: 600 watts RMS
not much comparable difference...except 3.6 db in efficiency, Obsidian has stitched surround and the obvious $47.00 ea. in price.
based on facts, with each sub is it's optimum enclosure with all power and source material being the same, the Obsidian will in fact shat on the skar 10...and I would bet on the 12 for that matter.
ohhhh itll be perfect! just not sure what kind of box to make
Skar VVX10:Re : 3.8 ohms
Fms : 26.6 Hz
Res : 60.4 ohms
Qms : 4.32
Qes : 0.46
Qts : 0.42
Rms : 8.6 kg/s
Cms : 0.16 mm/N
Mms : 222.6 gr
Nref : 0.10%
Bl : 17.5 n/a
SPL : 81.8 dB
Vas : 24.5 L
Rp : 34.5 ohms
Lp : 53.5 mH
Cp : 909.5 uF
Le : 3.09 mH
Rms : 600 Watts
2.5" Voice Coil
Obsidian 12:
Re: 4.0 Ohm
Fs: 33 Hz
Qms: 5.21
Qes: 0.56
Qts: 0.51
Vas: 34.4
Le: 4.36 mH
BL: 19.1
SPL: 85.4 dB
Sd: 490 cm^2
Mms: 243.1 g
Xmax: 20mm
thanks man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif why are they going for so cheap? to get their name out there?
---------- Post added at 01:22 PM ---------- Previous post was at 01:23 PM ----------
Fms : 26.6 Hz
Res : 60.4 ohms
Qms : 4.32
Qes : 0.46
Qts : 0.42
Rms : 8.6 kg/s
Cms : 0.16 mm/N
Mms : 222.6 gr
Nref : 0.10%
Bl : 17.5 n/a
SPL : 81.8 dB
Vas : 24.5 L
Rp : 34.5 ohms
Lp : 53.5 mH
Cp : 909.5 uF
Le : 3.09 mH
Rms : 600 Watts
2.5" Voice Coil
Obsidian 12:
Re: 4.0 Ohm
Fs: 33 Hz
Qms: 5.21
Qes: 0.56
Qts: 0.51
Vas: 34.4
Le: 4.36 mH
BL: 19.1
SPL: 85.4 dB
Sd: 490 cm^2
Mms: 243.1 g
Xmax: 20mm
Save up and get some sundown sa's. This would be wise, especially if you were wanting to get another mb quart down the road. The sa's just handle power better than anything ive seen in that price range.
Foote11
Foote11
Iowa
Foote11
