2 12s 2 amps
wire the subs to 4 ohms ,same box line match the amps and you should be fine .and dappa the jl 1000 are not 1 ohm stable no need for separate enclosures either.
i never asked which JL 1000's
I assumed slash in which case all ohm loads from 1.5-4 are stable and with anticipated rise , he should be ok , but will require some carefull tuning
but if he has the JX 1000 then he still is not optimal then he will have to wire up to 4Ω and then he is not getting the full 1 k but will deff pound depending on enclosure
I only suggested separate enclosures in the event on equipment failure
frogcase2002
frogcase2002
hamilton, ohio
frogcase2002
BP1Fanatic
BP1Fanatic
