2 10s or 1 13.5" Woofer
Im having a hard time deciding on either 2 10s or 1 13.5. Im thinking 2 10" JL Audio W6v3 or 1 13.5" JL Audio W7. Both will be ran off the same amp which is a JL Audio HD1200/1. The 13W7 needs about 2.5 net volume tuned to 34 hertz and the 2 10w6s need 1.5-1.75 net volume tuned to 34 hertz. The 13w7 has a cone area of somewhere around 135sq in while the 2 10s will have 157 sq in. Which do you think will hit harder and sound better?
wow idk.. w6 good sub but i wonder if they need more than 600 per sub to really be pushed hard of course same could be said for w7, i guess i'd go with 1 sub with more power.. maybe someone knows about jl it ain't me..
Are you set on using JL?
you can get louder for way less
omg normally i get yelled at for that and didn't even think about it this time.. OP i suggest a FU 1250 12 or 15 (honestly a fu 750 like mine would be awesome on that power and it's $189 made in us see my avatar)
For what vehicle? What's your budget? Get rid of the overpriced w7...I know it's a good sub, but for the money there's tons more options out there.
nah, keep the W7, suckers gonna hit good in there. i have a 12" RE SE sealed in my Accord. shakes my entire car with ease and sounds nice in clean
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
DodgeRam1500
Sacramento California
nauc
    May 24, 2024
    May 23, 2024
