1st truck box attempt - FREE box build
Some as low as $50 for a ryobi one. Then make a plwood top and fence extension for cutting up to 47" pieces Makes boxes alot easier when the pieces are the same size. also makes great angle cuts.
http://miami.craigslist.org/search/tls?query=table+saw&minAsk=min&maxAsk=max
I do just fine with my circular saw. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
No room for all that anyway. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i agree with ls2. i love my circ saw. i made a few helpful tools for lining up cuts in 1/3 of the time. ive made about a total of 5 - 6 boxes over last 5 months. i did a box with 6 sides for a friend in his explorer to fit behind the 3rd row seating (small debth lots of angles). my circ saw has ability to angle cut up to 55 degrees. so really i can cut anything depending on my rip direction.
if you havnt made it already ls2 i suggest you do this.
get a long piece of wood. wider than the width of your saw. then take another piece of wood that will be equally as long or a little longer (you can cut off the excess) lay this one on top of the other piece of wood. glue it down. screw it down. make it a permenant bond. just make sure the piece on top of the first has a perfectly straight smooth edge. then when the jig has dried. put your circular saw on the bottum piece and have it ride against the top pieces edge and rip through the excess width of the first piece. tada you have a rip guide to however long you want to make it.
So now all you gota do is layout the lines of the cuts accurately then lay the rip guide flat against the line and clamp. you dont ever have to double measure for the width of your circular saw again
AND if you smart about your jig like i was. i made sure i had excess width on both the top and bottum boards so that when i flipped the rip guide over, i have the opposite rip direction width of my circular saw accounted for. =]
i love the my grandpa's wood working tips.
Hope this helps you or anyone else using circ saw.
i still think i will eventually get a table saw.
Mike-
Steady hand works for me. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
not for me so much //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Mike-
What are the odds you took pics of this?
Id really like to see!
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
854
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
963
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
431
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
OoMesKoO
    May 18, 2024
    May 18, 2024
