1996 impala ss build log
Lookin' good man.
Where did you get the SEM dye?
off blue heron and cherry road cant think of the name of the place ill look on the reciept when i get home tonight and pm ya
works on plastic too :p
just gotta do good prep work it came out nice i was very pleased
Cool, let me know. Want to do my dash and trim in the Civic. Does it adhere well to vinyl? My dash has that softer vinyl with the foam or whatever under it.
works on vinyl real well just have to make sure u clean the hell out of it first and have a place to spray it with no wind
comes out very nice
what grit do i use to sand fiberglass, im going to sand and do one more layer tomorrow and test fit the back dash cover tomorrow before i wrap it
I would use 60 - 80 grit to smooth it down than 220 to finish it with (if you're painting it). If you're coating it with material, just rough smooth it.
thanks yeah im just gonna carpet it cause it is gonna be takin a beating from the bass that way if/when it breaks i can reglass and recarpet
painting and prep is alot of work
thanks for the tip i was wondering how to get that shit to stay tight first time using it and i like it alot better than the plastic tubing
never used heat shrink either how does that work??
tis a tube that shrinks when a certain amount of heat is applied
simply slide it on the wire and take a heat gun to it
home depot???
i see the connections u are talking bout the 2 on the alty, those were the temp ones anyway the mechman alty should be here by friday so i will fix em
where do i buy heatshrink homedepot has it???
thanks for the advice
waitin on the mechman still hopefully tomorrow so i can get the alty in
got some ngk plugs, msd coil, and HIDS done, emission AIR Pump removed
pics of HIDS 10k hi/low kit
back dash will get wrapped in black and installed this weekend and the alty will too
and stinger batteries and holders will be installed as well pics tomorrow again
stil no pics of the whole car? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif have u smoked the tires yet? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
haha not yet gotta take it easy on the ****** for break in only have 97 miles on the new ******
i will get pics tomorrow waitin for my boy to come over and detail it. The outside is filty from shitty weather and dirty fingerprints from the work on the motor
gotta get some so i have before and after shots got custom urethane bumpers for front and back ordered and deciding on a ram air hood too then its going to the paint shop
pics of mechamn unit got here today //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif (did findout the wrong pulley tho //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
installed pics tomorrow
got the alty on also switched all the hoses under the hood to the silicone goodyears and flushed the cooling system again today while i had all the hoses off
started installing the wiring for the extra batteries in the trunk 2 stinger spv70's goin in maybe tomorrow or monday
hemi=22s
I Pop Bottles
hemi=22s
west palm beach, fl
AlpineUser
michigan born
    May 14, 2026
michigan born
    May 14, 2026
