1993 fleetwood factory amp power rating
  • 2
viperrgh2
usa
Just got a 93 fleetwood going to install an older pioneer deck and some a series speakers wondering if It's worth the time to run new wires from the deck to the speakers or use an amp integration harness anyone have any idea what the power rating is on a 93 fleetwood factory bose amp? Thanks
If those are your only options running from the car's external amp or running from the deck. You will want to buy the 100.00 wireharness that you need to use the car's amp. Money is better spent on buying a new aftermarket 4 channel amp. You will have much better sound overall. There are amps in the classifieds or on ebay that will blow away stock amplifiers.
Well instead of the harness I'd rather spend time running my own wires from the deck to each speaker for the fronts just grab them in the kick panel... I have a few four channel amps laying around but i'm not keeping the car long enough for that just wanted to give it some decent sound before I sell it... If I was going to use the factory amp I thought there was a harness just behind the radio that you hook up to the rcas but after further looking into the parts metra has to offer I was wrong just going to run new speaker wires... thanks
Contact ANS he has a used Focal 8 Channel DSP that went for 1,300 bucks and is selling used I think shipped for 450. And from what I have seen and...
13
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
viperrgh2
viperrgh2
usa
viperrgh2
    May 24, 2024
    May 23, 2024
