1989 Box Caprice, 2 Hifonics Goliath 15's....Build
put in on the pos. on the amp and neg of the amp...??
You meant from the amp? If you are testing to see if you're putting the right load to the amp from the sub, just test the sub wires and connect them to the amp once you find the right load.
Take coil #1 red and hook it to coil #2 negative, and wrap it up.
Take coil #3 red and hook it to coil #4 negative, And wrap it up.
Take coil #1 negative and hook it to ch. #1 negative on the amp
Take coil #2 red and hook it to ch#1 positive on the amp
Take coil #3 negative and hook it to ch. #2 negative on the amp
Take coil #4 red and hook it ch. #2 on the amp.
This gives you a 2ohm x2 load on both sides of the amp
wheni just touched the pos and neg to the amp with the DMM reader it just started flashing a bunch diff numbers. how to i get it to show ohm load without taking the kicker 15 out?
btw i just got an oldskool kicker 15 in there for now till i get time to put the hifonics sub and wire rightohms...etc
Newer Pics 4 u Guys
Donks
Donks
CO, Ohio
GavinVoy
