1986 Chevy Caprice Classic
It's a pain to take apart. The heater control assembly and radio are attached together, and it's not just a matter of unplugging harnesses to pull it out.
You should find 2 screws above the heater, and 2 more inside the ashtray cavity after you remove the ashtray. Removing them allows you to pull the whole assembly a few inches out of the dash, but the cables at the back of the heater controls will hold you up. If you look behind the glove box, you will find a point where one of the heater control cables is anchored; you can release it to give yourself some more room.
Once you have the whole setup pulled far enough from the dash, look on the BACK side to find the 4 screws that hold the radio and air conditioner controls together. If you can get a socket or nutdriver into position to remove these, you should then be able to unplug the radio and remove it.
UrbanSounds
UrbanSounds
Orange County, CA
KaeZoo
michigan born
    May 14, 2026
michigan born
    May 14, 2026
