18's that can handle 6kwrms?
JEXTEL
i want to get rid of my BTL's and try something new..Something that will hopefully have me in the 155 dB range
only thing that comes to mind is Atomic APXX's and Kicker Solo X's any thing else?
PS im leaning towards the solo X because of cone area
EDIT 6kwmrs per woofer {kinda daily //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif}
good ****... there is better ways to get at 155db than a single woofer with 6k
good luck on finding coils strong enough
edit: not sure you want a single sub setup ?
look into the the cascade omegas they should be able to handle 6kw rms....
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
only woofers i've ever used that will take that are tsns's..
i ran a pair of gp3000d' pro's on 16v strapped on one and it took it like champ.
sure if i put the amps @ a 1 ohm reactive load on a sine wave the woofer would have failed, eventually... But on music w/ the spider package i have its no problem.
My TSNS takes gobs of power as well, but mine just doesnt like the lows of music that well.... even in different boxes. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
To the OP... your gonna want to find a driver with a 4" coil. Helps with the heat and everything to have a larger surface area.
You can try what RAB suggested the RD Audio SuperHeavyWeight (SHW) im sure Steve can whip you up something that will meet your needs.
If your not exactly STUCK on an 18 that needs 6k, divide the power up, you will gain a LOT more.
If I may ask... what amp is this 6k coming from??
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
854
$500 is not unreasonable, but just know about alternator shopping: There are two numbers that matter: The amp output at or near idle (what's it...
880
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
Specs https://www.skaraudio.com/products/vxf-15-inch-car-subwoofer
JEXTEL
JEXTEL
Bridgeton, NJ
Savag3
