15L7 questions-ported/sealed/invert help?
YZmoto125
A friend of mine was recently given a deal on 2 15L7s with 2 zx1000.1s with it. He has done some fiberglass boxes in the past, all sealed, and wants to go ahead and make a sealed box for the two 15s that is about 6.6ft3, both in the same chamber. I was telling him he should port the box, but with his space provided and both of us lacking knowledge of how to make a good ported box, he decided that we should keep it sealed.
On one of the subs however, he wants to do an invert mount on it, is there any problem with one inverted and one normal in the same chamber? Also, what else would we have to do to invert the sub properly(wiring changes or anything)?
He also was thinking about using the material that you put inside of sealed boxes to make it feel like it is a bigger box(completely blanking on the name of it right now...). What do you guys think of this idea? worth it or not?
Also, how would his 2 L7 15s sealed in that fiberglass box compare to my 1 15L7 with a zx1000.1 in a ported box that was professionally made out of MDF? Any help is greatly appreciated, we both still have a lot to learn with car audio.
You can invert one and not the other, just remember to switch the polarity on the inverted one. Polyfill? How they would compare, I'm not sure, there's so many variables. If you can port them, deffiantely do it. It'll make a nice difference.
never personally seen L7s sealed, but you should do it and give us a review. i would make it out of mdf first so its not as time consuming that way if you dont like the sound of it you can scrap it without too much effort lost.
i have 215L7's sealed in 7cubic feet with a zx1000.1 to each of them. they slam, it make my truck backglass wiggle. i ran 0gauge to a distroblock split in 2 4gauge wire to the amp. i have a 80amp alt and i have very little dimming
yea his set up is going to be very close to dflw_99s, he was just going to buy one and do what I did, but then since he got such a good deal on the set up he just went for 2.
polyfil is what im looking for, what do you guys think? use it or not on the fiberglass box?
bump
also, 15L7s when put in the right box can actually sound really good sealed and retain a lot of SQ, and when you have 2 of them, they are plenty loud.....
what do you guys think about polyfil for this set up?
bump
Throw 3 to 5 pounds of it in the box... it doesn't hurt anything, and may help even out any upper bass peaks.
anybody else have an opinion on polyfill?
Also, how do I invert the polarity of the sub? And I read somewhere that L7s sound really badly inverted, anybody have any experience on this?
YZmoto125
YZmoto125
Minnesota
YZmoto125
