1243d with bandpass help!
Also, whats the result of too little port area? Facing subs toward eachother head on? Facing them together at 45 degrees? Having the type rs playing 5-10 h wont damage them, will they? The specs say range is 20-200...any leway?
I really appreciate all your help... A month ago i didnt know the first thing about car audio...but this forums been amaing! You guys rock haha
too little port area can cause 3 things in 4th orders. massive port noise, less output, more controlled output.... usually all 3 happen at once for a new guy. not saying you couldnt do small port area but there is a fine line in small port area and a hole in the box
Lol i know what your saying... Im trying to stay away from pvc and just do slot ports...also from what i drew up its more of a labarynth design..do 90 degree angles effect anything? Also. If it started being 2", then the board was 4" from the side wall and went back to 2 wide and so on for 3 turns, what happens? Essentially a multi-width port i guess..any harm there? Or a snail shell box that hits 10x harder? Haha
How different would it be building just a ported box? Is port tuning pretty much the same?
And another bandpass question: what happens when the drivers are turned around? (Magnet in ported area)
Is there anyway someone could help me out with all the winisd dimensions? Id really like to play with the different types of boxes..im off tuesday and plan on building. I plan to make a sealed, ported and 4th order for these 2 12s by the end of april... Winisd would be a HUGE help!
Well i finally got winisd to work, but i cant change the reading to SPL.. it says error something divided by 0..and im not sure why the line counts from like -30 to 0....what does that mean?
Mp3 files and the like measure volume in terms of decibels with 0dB being the loudest. I assume winisd adopted the same concept, though it's kind of a strange way of labeling the graph.
Its been fun folks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif illbe putting my top 3 designs in winisd tomorrow and see what will work best for what i need. Ill be building on monday, wish me luck!
iggiafrica
iggiafrica
Meridian, ID
iggiafrica
