12000 watts and one 12'
those amps are 3k@2ohm they just say 6k to make it look better and get stupid people to buy them thinkin they are getting 6k watts
i really dont see that setup doin 149 since u are almost blocking the truck with those amps a lil video would clear things up... also what meter are u using
and its no term lab thats for sure. the most it has every been off was 3db. some of are cars were actually louder on term lab, some not. so it was a more around number. so 149.7 give or take 3db
well i have two red top batteries. one under the hood, one in the wheel well. 2 gage running from the first batt to second. (i will be putting a second run soon). . then from the second battery is all 0 gage. all grounds are o gage. i will be doin the big three soon. and i have an 18farad cap, but everybody is tellin me to ditch it
yes the cap is probably not helping at all.
what ohm load are the amps seeing?
your electrical is pretty weak for 6000watts. voltage drops must be really bad
the amps are almost as long as the box is. the only area really blocked off is above the box where the top amp is
and yes voltage is normally around 14.8, but if i romp on it to long the amps can clip out. . not good. normally have to rev the engine while tryin to meter it to keep up voltage
what did the meter look like
it was a box that read out the numbers. plugs in to cigarrete lighter and one end is like a microphone. cup our hands around it and shove it up under the dash. its kinda jank i know, but its always been real close to the sam after we go to a comp.
they say its a spl sub, not made for music. so is it wise doin a street beat with it?? (not really sure why they say its not for music)
alerotdx
alerotdx
iowa
Lil Poot
michigan born
    May 14, 2026
michigan born
    May 14, 2026
