12000 watts and one 12'
we bumped some music thru it and got a 149.7, threw on a hertz disc and couldnt get past 146. so i will prolly street beat with it. plus if i did anything but street beat i would get ***** because of how much power im pushin. .
there is no reason it would meter higher on music than with a tone. there are probably a couple of reasons for this. you either didnt play the right frequencies, or when you were playing music something his the meter causing a spike in the reading.
and 6000watts on 1 sub for music is never a good idea
maybe my shit was just hot, we couldnt really explain it. the sub is like 77hz, the bow is build for 48hz. so we went thru 40 to 60hzs. ..
each amp is 3000 watts rms. 6000 watts max. check out the massive site, it says it right on there. they are 2 ohm stable amps
what do your electrical upgrades consist of? what ohm load are both of the amps seeing right now?
max watts are watts that do not exist. most people on this sight dont acknowledge them
well i have two red top batteries. one under the hood, one in the wheel well. 2 gage running from the first batt to second. (i will be putting a second run soon). . then from the second battery is all 0 gage. all grounds are o gage. i will be doin the big three soon. and i have an 18farad cap, but everybody is tellin me to ditch it
alerotdx
alerotdx
iowa
Lil Poot
vegang
vegang
