100A AGU fuse, big-3
umm i dont think ur supposed to have more than like an 80a on 8awg... and 150 for 4awg...goto darvex.com and look at the stinger MIDI fuses and fuse holder they are like mini anl fuses, but they are cheaper and works alot better than agu fuses, its like $20 for the holder and 3 fuses
AGU fuses come apart alot of times, MAXI fuses are used in your amp and i think they only go up to 80a MIDI are like 30-150 i think and ANL i think is like 50-300, if your using 4 or 8awg wire i would use MIDI fuses, and for 0awg i would use ANL
ah, so its a matter of availability and options.
looks like ill go with midi for compact sizing and cheaper than anl
thanks for the info
one last question: 100A or 125A on the MIDI fuse on 4ga power wire that will have about 2-3 feet of 4ga on each side of the fuse holder?
its gonna looke like this:
+battery: ======= =========+alternator
the "=" is my 4ga power wire. this if for #3 of the "big-3"
btnhfan, thanks for the offer, but im gonna order off sounddomain.com since im ordering bunch of other goodies.
oh yeah i forgot u were doing the big 3 not for the amp, but i think the fuse placement still applies, and need to be close to the batt since thats where the power is coming from. I would also recommend getting your stuff from http://www.darvex.com instead of sd.com it should be cheaper and thats the other place i kno of that you can get teh MIDI fuses. If you havnt already ordered the wire i would get it from http://www.weldingsupply.com they also have connectors on there.
its only gonna be 2-3ft long at most. but your right, i think ill just cough up more bucks and get new terminals for 4ga and fuse it by battery.
rather pay more to be safe than sorry
thanks for the heads up
M@nJo
M@nJo
bay area
M@nJo
