100 fuse
  • 2
you could get it from crutchfield or prolly cheaper from a local shop, for a 100 amp fuse you wont be able to use a glass fuse you will have to use the waffer style hi-amp fuses and no i dont think there is a kit with that big of a fuse and holder they usually only come with like 60 amp fuses
oh i see them now but where can i find a fuse holder for those type of fuses??? and what do they look like? Never seen a fuse like that before.
lol boy i am just answering my on questions tonight. I found the fuse holder i just have one more question. i have an amp kit already. Now i have 400.4 amp and i am getting bd1000.1 now i was think about just changing the power and ground and fuse. Should i get different RCAs cables? or will the ones i have do fine. there just regular not the expensive one.
what size is the new power and ground wire? as far as the rcs i think any pair will work fine you r powering subs right? i dont think there is much difference i mean if you are going for supper high sq and running the amp to mids and twets then maybe ya go for some high quality stuff but for subs i dont think you would be able to hear and noticable difference
Product Brand & Model: I have a Mosconi D2 100.4 DSP amplifier and Controller for sale. It's 4 channel amplifier with a built in DSP. Condition...
  • Locked
Here's a longshot. I'm trying to find a second set of these tweeter mounts. They are flush mounted, and fit my tweeters better than the mounts...
I loved US amp back in the day. worth the investment
Set the voltage to 20 volts via DMM and it will equal out to around 100 watts. https://www.the12volt.com/ohm/ohms-law-calculators.asp#voltage
mr.cableboi
Pimp Of The Year
mr.cableboi
Richmond,ca
EPanther99
    May 24, 2024
