add amp to mach 460
  • 3
I have a 2000 mustang. You have to buy a amp that is compatible to the factory amp(you could bypass the factory amp but the radio won't work), if not you will get a terrible engine noise, and you can't filter it out. You could also buy a aftermarket head unit and bypass the factory amp, and then you could use any amp. Good luck, I learned the hard way, $$$$$.
You don't even have to make sure it is compatible.. just find an amp with speaker level inputs and tap the rear speaker leads right b4 the speakers and go straight to the amp..finding the remote for the factory amp is what will be difficult.
Mike
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
You can use two front channels to power the full range speakers, then use the rear channels to power a sub. IMO, for that price I would rather use...
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
3K
I took a quick look at the manual for the Jensen. It only says that the usb is compatible with memory sticks and iPhone and iPod. It makes no...
steagan
steagan
omaha, ne
mykeys
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
