$100-300 700 watt 12" sub?
I have an American bass 100.1 amp(1500 watts)powering a Dayton 700 Watt sub I am curious if anyone has had luck with a $100-300 700 watt 12" sub in a ported box? Thank in advance.
ssa gcon, cab ultra, FI alpha, FU750, nvx vcw, ts several more and all those are under $250.. ps look at my sig..
I would like to get the best sq while adding some bump to my system.
yeah if u want sql gcon or cab ultra or fi alpha but u said $300 so look at FI ssd (FI makes ssa subs) u can get it right at $300 good size made in us sub..
above i would do the fi
Incriminator Audio Lethal Injection 12" 1000 Watt Subwoofer
SSD Series - SSD12 | Fi Car Audio
if below 200 i would do the cab ultra
* NEW * CAB-ULTRA-12 12" 750W SUBWOOFER - Car Audio Bargain
Flatlyne 12 Incriminator Audio 12" 600W Flatlyne Series - SSA STORE
if your willing to go above 300 for 350 this would be the ultimate sql sub. sounds amazing
---------- Post added at 12:40 PM ---------- Previous post was at 12:40 PM ----------
Flatlyne Series Subwoofer
some info on it
What do u guys think about soundqubed hds?
In a Built spec box/enclosure, I can vouch for the HDS310s and 12s..Other than that.. Id look at an ID Max , or a Dayton HO series..Even an ARC, or a Boston 13" Oval if you can find one, for SQ purposes.Gcon would be nice to have for sure.Itried all kinds of different enclosures from sealed to ported and could never get my SA 12 to perform decent enough for me.Got tired of building enclosures for it
635
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
Sony got a bad rap because of their xplod walmart stuff, but they were one of the first one ohm amps i saw. I couldn't tell you the model but it...
429
  • Locked
Additional photos, videos, or live feed available on request.
miniman
miniman
Montgomery, MN
hispls
    Jun 15, 2024
    Jun 15, 2024
