10" type r's werent as loud as I thought?
Nico Koutouzis
Hey guys I set the gains using a volt meter to 31.6 ac volts at 1 ohm (1000w) using a 50 hz tone and then I tested the sub with music and it still didnt sound very loud. It's an mb quart onyx 1000.1 D and there are 2 swr-1043D's in a 1.3-1.4 cube sealed box. The volume on the HU was 34 out of 40 which is a tad above 85% volume. I also tuned the subsonic and low pass filters by ear. Any opinions? (p.s. I tested them ourt of the car next to it in closed three car garage but I should still hear a good thump to em)
Edit: Everything on the HU was set to flat... should I try bass boost?
yes they are wired to a 1 ohm load. And idk what the filters are set to. I just played an instrumental and when I heard the cymbals/ high pitched instruments go away was where I stopped.
I cant build a ported box. I dont have the trunk space.
---------- Post added at 09:56 PM ---------- Previous post was at 09:55 PM ----------
I wold think it is amp settings. Even in a sealed enclosure they should do decent.
thats what I was thinking?
He said he tested the outside his car so it sounds like he wants to be able to hear the bass outside also as if it were a ported box.
He said he tested them out of the car. Meaning he took the enclosure out and set it beside the car.
Amp settings are the issue here. Would a different enclosure help? Perhaps. However, he should adjust what he has now to see if he can make it work.
in a g35 coupe. Need to keep some trunk space as it is my dd (excluding winter)
Get a pic of the control settings on the amp and how they are now. We can help you with that. Also, it never hurts to go back and double/triple check the wiring. In many cases the easiest thing to over look is the issue.
If you have a DMM check to see what is the resting ohm load is.
no no the only reason I tested the subs out of the car was because I needed to wait for the old man to come home to help me put the subs in the car. (they are car specific and a nice tight fit) I would never be able to do it on my own. It was a 2 man job. Yes it would sound cool to have a good thump outside the car when the subs hit as well but at this point im looking for good output.
Nico Koutouzis
Nico Koutouzis
Hartford, CT
ThatChevyGuy
