10" midbass in a custom three way
I really wanted to do an all morel compnet set up but I bought a pair polys and a pair of css fr125. I was wondering if another pair of poly 6.5 would be ok for my mid bass or try a pair morel 10's or 9's a pair of morel elite tweeters and call it a day for my front stage? Also is running 4 pair of morel tempo's in my rear doors over kill?
First, yes the 4 pair of Tempo's is way over kill. With the front stage your working on they can only hurt the overall sound of the system, if not controlled. If you have no way of removing a pair of them and making them the door over good, keep the volume/level of them way down. Tune your front stage and with out them on (them being the Tempo's). Once your happy with the front stage raise the volume of the rears to you can barley hear them. Use them just to create a sense of space.
Know to the main matter at hand. Dual poly's or the larger morels would be a very good choice. With the 125 and the elite tweeter and your choice of midbass you would be could to go. I say just go with the poly's since you have them already and get the extra pair.
Good luck with the system.
I also am interested in trying a pair of these morel midrange speakers I have no real experience with these bu I like their specs and think I could possibly make them work. I was thinking I could use a pair of these in my front stage along with that CSS FR125. Any suggestions anyone?http://www.madisound.com/catalog/product_info.php?products_id=8286http://www.madisound.com/catalog/product_info.php?products_id=562http://www.madisound.com/catalog/product_info.php?products_id=8441
No, please don't do this. You have no did for all these speakers in the system. The FR125 is a very wide-band driver, it will be fine for midrange duty and will give you more tuning option. If you want to do dual midranges do dual FR125 or do a MTM setup with dual FR125's and the elite tweeters
I have a few products I will like to try by morel. I thnk as far as blending or imaging I should look into using the same brands. Im like the specs of the CSS FR125's and the Poly 6's. but again I am unsure if they will work with my rear stage morel tempo 6's. So my qestion is Should I buy another set of polys and use them up front as my midbass and use only the pair of CssFR125 as my midrange Or should I add a morel midrange in the pilar as well as the CSS FR125 in the kickpanel as my my mid ranges? So my front stage could be Two poly 6's in each door as my midbass and a pair of CSS FR135 in the kick panel and a Pair of morel MDT 55 midranges in the pilar along with a pair of morel supermo 130's or a pair of morel elite tweeters as my highs and for m y rear sage two pair of morel tempos in the rear doors andpossibly three DD3518's as my substage. Any comments and or suggestions?
Here are some componets I am looking at
http://www.madisound.com/catalog/product_info.php?manufacturers_id=141&products_id=8435
http://www.madisound.com/catalog/product_info.php?manufacturers_id=141&products_id=574
http://www.madisound.com/catalog/product_info.php?manufacturers_id=141&products_id=577
http://www.madisound.com/catalog/product_info.php?manufacturers_id=141&products_id=8287
http://www.madisound.com/catalog/product_info.php?manufacturers_id=141&products_id=595
http://www.madisound.com/catalog/product_info.php?manufacturers_id=141&products_id=590
My friend want brand you have has nothing to do with the blending or imaging of your system. YOU DO NOT HAVE TO HAVE THE SAME BRANDS. Choosing the right with the correct frequency responses , tuning, and install are the most important factor. Choose the correct drivers for your needs. Then install them correctly (Installs is about 70% of having great sound in your car). Then take time to tune it to your likings.
Just use:
2 poly in each door (midbasses)
FR125 in kicks or dash/a-pillars (midranges)
supermo 130's or morel elite tweeters (tweeters)
What ever subs you choose.
And as i stated above use the tempo's be keep their level very low.
These have been used for a few months and then were pulled for pro drivers to take their place for more output. These are 4 ohm drivers and in...
Dayton Audio GF180-4 6-1/2" Glass Fiber Cone Woofer 4 Ohm (parts-express.com) I have eight of these going in the car. 2 per door. Great little...
teedot231999
Mr. Beat's
teedot231999
corona,NY
Here-I-Come
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
