1 set of component in the front??
DIGIDIGIBOMBO
Hi, i have 2 set of components clarion srs1751HX, i will put 1 set in the front doors/ and 1 set in the back. Would it be better to put 2 set of 6x9" in the back rather than 1 set of component? i used to have the 4 6x9" in the back and they did have a great midbass kick. I do care about front stage sound as much as rear stage....i am affraid the set of component in the back rather than 2 set of 6x9" is gonna have a lower midbass:( thx
The inner door volume will be the sealed enclosure dude, is it ok? I am having difficulties deadening the doors, too much dirt inside and the special aluminum foil keeps on falling down. i must use the aluminum foil used for noise reduction right? Thx
Use Goo Gone or some other cleaner to take the crap off of the door metal...what kind of deadener are you using? It isn't "aluminum foil", though the outer layer may look like it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
DIGIDIGIBOMBO
DIGIDIGIBOMBO
Leb
JimJ
michigan born
    May 14, 2026
michigan born
    May 14, 2026
