1 ohm stable 4 channel amp
Theo
I got impedance issue with my door speakers being at 2.7 ohm and my tweeters being at 4 ohm which shows my current amp a impedance that it can’t handle for long. My question is: does anyone know of a 1 ohm stable 4 channel amp that won’t break the bank.
How are Cervin Vega amps?
So they're wired parallel w/o a component crossover?
At a minimum the tweeter has a filter, right?
So at low frequencies that filter will present high impedance keeping the overall impedance of the system pretty much determined by the woofer.
At high frequencies the inductive reactance of the woofer will cause it to present a much higher impedance which should counteract the relatively low impedance of the tweeter.
If your amp is struggling my guess is there's something else going on. What amp is it?
Is that amp any good? It meets specs needed but how is the quality?
top tier. I've been running 2 ohms bridged aka 1 ohm for a while now, runs cool, efficient and powerful, does more than the rated 100 watts on the amp dyno.
This is the 8604, basically the same as the 8704 because its an older generation. The 8704 is a newer generation, has better parts and build quality improved over the 8604
T
thanks a lot. I will definitely buy this pioneer amp after watching the dyno test
Theo
Theo
Galveston Texas
Theo
BP1Fanatic
BP1Fanatic
