?1 JLW0 at 2 ohm possible!?!??! i'm new
SQcivic
Denver
i'm new to this and want to know if its possible to wire a jlw0 to 2 ohms
i was looking at jl's site and realized that i cant wire one jlw0 to a 2 ohm load, which pretty much wastes an amps pottential
if this is true
Sorry dude, but the sub will still be 4 ohm. You can't bridge a single voice coil sub, and the W0's are single voice coil so you can't change what ohm the amp sees. For these subs you can either use a 2 channel amp or a mono subwoofer amp. They both basically serve the same purpose. To the second part, no, it doesn't really waste an amps potential. Most 2 channel and mono amps are made to be most efficient @ 4 ohms. You will only get around 1.5 times the RMS rating @ 2 ohms that you would get @ 4 ohms.
It also lowers the amps efficiency and raises the current draw.
5
617
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
420
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
SQcivic
SQcivic
Denver
taylor
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
