1/4 ohm stability
Originally posted by djjdnap doesn't JL amps handle like whateva you throw at em??//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
below 1ohm bye bye jl. they have a power supply that is incredible though and allows for an output change that is so slight it's not worth posting dif. #'s of output @dif ohm loads. the jl1000x1 will do 1kw from 4-1.5ohm.
adam
Originally posted by bumpin_blazer dunno it was an example lol. point is there are plenty of 1ohm stable amps that do 2kw. i think they are though b/c steve is running a pair on his 9515's which are 2/2. i dunno though what would help is what kind of power this guy is looking for.
adam
They are ~ 2000 x 1 @ 2ohm...the stock one's go to 2ohm...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
- Steve
no, they can only go down to 1.5 Ohms, and still only put out 1000 watts. way to expensive and weak to be good spl amps...and the new orion, im pretty sure are only 1 ohm stable..but they are 2.5K at 1 ohm:D
Originally posted by havoc06 no, they can only go down to 1.5 Ohms, and still only put out 1000 watts. way to expensive and weak to be good spl amps...and the new orion, im pretty sure are only 1 ohm stable..but they are 2.5K at 1 ohm:D
if your talking about your MMATS amps the old school amps only did 1.5ohm the new ones will happily go under 1 ohm trust me on that one. as i said on AIM man your doing something really wrong to not like them amps and juggy subs:D.
adam
Originally posted by RangerMan Must have 2 Dual 1 Coil subs...Shockers or something...
Earthquake D3 goes down to .25 ohms
Old school US Amps and Orions go the same.
indeed they do //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D;)
also, there were one or two older soundstreams that were able to do the same. i think the SS 10.0 was one of these - im quite sure it is at LEAST 0.5ohm stable.
but keep in mind at such a rate, there will be HIGH CURRENT draw, espceially from the class A/B camp
j:)
DaBaller504
Livin Loud In Da Blazer
DaBaller504
Westover, Pa
bean
