dman4486
RememberedHowToChangethis
Decided it was finally time to run a 1/0 to the back
comments and suggestions appreciated
Raptor 250A ANL
Since I will still be using this vehicle off road, I decided to run the 1/0 through the frame such that it would not snag on anything
Drilled a hole under the passenger seat and formed the edges as to not damage the insulation
The wire follows stock wiring to the wheel well, and then follows the floor/well seam, you can see where it emerges
I used GOOP to seal and suspend the 1/0 where it passes through the body, and will do the same for the ground when i drill its hole through the floor under the rear seat..
Raptor 250A ANL
