1998 mystique amp install
awesome dude thanks a bunch
yeah you should not even have to drill depending on what size wire you are using but if its bigger then the hole make it wider with a drill and get a nice grommet!! to run the wire threw so it will have a good tite fit and the wire don't get cut
I have a 2000 contour - they should be about identical. If it's an auto there should be a convenient grommet where the clutch cable/hydraulics would normally go through the firewall.
I ran 4 ga there and it worked just about perfect.
You have to pull back the carpet and some insulation.
ballin123491876
ballin123491876
moneta,va
n2audio
