07 Explorer Stock Sub Replacement
tryan77
Would like to replace and amp the stock sub in my explorer. It is an 8" hole with a shallow depth. I dont want to add a box as i need the space. I was recomended the following and im wondering if it is any good or if you have any other reccomendations...
Budget is $100
Tang Band W8-740P 8" Subwoofer
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-854
Thoughts, ideas, reccomendations?
I haven't heard a lot of subs but maybe jl or kicker. the kickers can take a little more power and can be used in a much smaller enclosure if you don't have a lot of room. like i said, i don't know a lot about subs but i have heard these and like them.
Search the Classifieds for "bones22"s thread. He has a few. Also check out woofersetc.com and take a look at Image Dynamics "ID8" subs. Do you know the volume of the stock sub enclosure? I know my mom's Focus has an 8" sub but I thought some of the Explorers had 6.5" subs. Are you replacing the speakers/head unit too?
Does your stock amp also power all your speakers? Will you be able to replace just the sub amp?
Stock amp does not power the speakers I the only power at the moment is my 9887.
I got a good deal on a Crunch p900.4 from a seller here and will be using that to power the fronts and possibly the sub until I can upgrade to a better amp for the sub and one for the fronts.
If a 8w7 doesn't fit maybe consider a 8w3. They only need .30ft^3 and have a super shallow mounting depth. Only 4.63".
I've heard very good things about the 8W3 on various forums. I've also heard them with 150w rms and 250w rms in a ported box. They sounded amazing! They absolutely beat my JBL 1202Ds in .64 sealed. I also believe that you can find the 8W3 in your price range with a little bargain hunting. Maybe you can spot a pre-owned one and come in under budget.
I just ordered two of them for behind the seat in my Sport Trac. The 8W7 was 6.83" in depth and .875ft^3 of airspace each. I couldn't fit them.
tryan77
tryan77
Milwaukee
Kil4Thril
    Jun 20, 2026
    Jun 20, 2026
