03-07 Honda Accord specific android touch screen w/ climate controls( issues, no sound)
  • 2
Mojoack66
Hello All,
I'm installing a full system in a 2003 Honda Accord coupe, when I bought the car the factory radio didn't work. ( no sound/ no display) So I paid to have a JVC deck installed with steering wheel controls in the lower dash storage compartment. (I now had music!!!) After a few years I wanted to upgrade the whole system. When I pulled out the JVC deck I found a rats nest of wires behind the dash. Nothing was properly tape or wrapped up, wires were coming apart...so, I fixed what I could see with proper crimps and heat shrink. I purchased a 10.1 " Android touchscreen specifically made to replace the factory unit completely, it came with the A/C controls built in. The installation was extremely easy, the harness it came with was plug and play connecting directly to the factory harness. At this point everything is working beautifully, I have picture, wifi, bluetooth,GPS....all amazing. But I have no sound at all...I had sound for about 2 days and then it stopped. I double checked everything is connected but still no sound. I re-connected the JVC deck and sound came out just fine. All speakers are connected to the factory wiring, but I was planning on routing all speakers to the 4 channel amp I bought. Would adding an amp make a difference with my no sound issue? I would appreciate any and all input.
Quick list of planned set up:
-10.1" Android 9.1 touchscreen specifically made for the 03-07 Honda Accord
-Front 6.5 Alpine type s w/ tweets
-Rear 6x9 NVX coaxial
-4 channel amp front/rear
-2 channel amp for subs
-2 x 10" NVX subs w/ ported box
Thanks
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
4K
When I first started with upgrades, I purchased a harness that allowed me to add an amplifier by tapping into the factory wiring. It was a PAC...
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
This is the max fuse sizes for the knu wire. The kca 4awg kit can supply 100amp to the rp1200.1 but it won't have enough left over for the rp75.4...
26
Mojoack66
Mojoack66
New Mexico
Firewalker
    May 31, 2024
    May 24, 2024
