02 Jeep Grand Cherokee Build (AKA Project Silent Night)
I'm just down the road in midland andnwould love to get one of the first demos of that Picasso //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There's a show in Muskegon on the 15th you should come out, I'll be there.
---------- Post added at 11:20 AM ---------- Previous post was at 11:20 AM ----------
Trying to upload some videos that Alec sent me from his snapchat story I have some stories I would like to try and splice together but I've never tried it before. If you click on them it takes you to Flickr to view them.
**** a 58 right out of the gate? You're just a stripper pole and some more deadening away from a 60. Awesome job man.
SPL is a fickle beast, I could do the things you mentioned and lose on the meter. I'm going to do a stripper pole for sure I don't know if I want to add more deadener yet or not.
Prove papermaker wrong.....oh 2 18's to get 160...yeah right has no clue.
The most notable build in my opinions for the 2 18 160 is Ray Pimley did a 64 or so with 2 18's in a 2 door Cherokee can't remember the power.
Is done often enough, not sure your point? Still though, in the put up or shut up department, OP delivered the goods.
For doing the whole build from start to finish by myself I couldn't be more satisfied thank you.
Meh, trollin' and hatin....always running hs mouth w/o any evidence on his end to back it up. You know how he is.
There's a Cherokee in Rhode Island that does mid 60's with 2 18s with 4 Soundstream XXX10Ks (about 6500W each real world). Probably has more in it but the windshield doesn't hold up.
There's a Seabring in New Hampshire that did some 160's with 2 18s and a pair of AB 500.1s. Current owner has 4 NS1s in it now and supposedly has tested 64's but has had head unit problems at the couple shows he went to this year.
There's another (retired) SPL vehicle around here that did 167's with 2 18s (an older Mitsubishi SUV IIRC). Very friendly SPL vehicle due to angle of windshield and the dash and windshield actually holds up to the pressure. He was running XXV Sampson amps.
In all cases these are veteran competitor's builds and have a lot of time testing and work into them. 160 doesn't just fall out of the sky.... Unless you're papermaker who is just so amazing at getting loud he doesn't even need to prove it with pictures or event results with his name on them.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
414
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
820
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
nkrell11
nkrell11
Mt. Pleasant, MI
hispls
    May 18, 2024
    May 18, 2024
