0 ohm load possible?
//content.invisioncic.com/y282845/emoticons/popcorn.gif.32dd9e22fd77e77bc3c907062768fcd2.gif//content.invisioncic.com/y282845/emoticons/goodorbad.gif.fe1f80382c74d93547176ee10a15b645.gif
IMO zero ohms of resistance is possible....
IE a piece of metal, or two leads touching each other...gives you zero ohms.
HOWEVER in a car audio environment there is no way to reach 0 ohms, because no matter how many loads you parallel down, you'll always have resistance of wire and resistance of connections.
it might have already been said but I'm not reading through all of it
same applies to those two leads touching each other...there's still resistance, its the exact same concept
I guess your're right.
Theres ALWAYS some resistance, even on the microscopic level (.0000000000001)
So...IMO there is no such thing as absolute zero resistance
only if your voice coils and power wire are made of TlBaCaCuO and are soaked in liquid nitrogen //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
don't ask... im doin my science project on superconductivity lol
it doesn't take abosolute 0 K for the majority of conductors to become non resistive. (-273 C) not that yall didn't know that allready. Actually most metals that you would assume that would be used in speakers reach there "inferred absolute zero around -240ish C" such as copper and aluminum. There are also alot of materials that reach there "inferred absolute zero" much much lower than 0 K. Such as Nichrome, Constantan, Mercury, and Manganin. Not that my 2 cents is worth anything //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Also, good conductors such as copper are not necessarily good conductors at extremely low temps.
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
424
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
280
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
976
Hoodlum007
Hoodlum007
Reno Nv
Lakota
    May 12, 2024
Brendon Jenness
    May 11, 2024
